Hello all.
I am having issues with my tractor not getting fuel from the fuel pump. I recently replaced the ignition switch because I was not getting voltage to the fuel pump and that problem is solved, yet I still cannot get it to start. I took lined loose at injectors as well as at the top of the pump and there is no fuel coming out at all. I am out of ideas and need a little help. I know that its possible fot the pump to go bad but tractor is only 3 yrs old and has about 300 hrs on it. Seems a little premature for that to be an issue.
I appreciate any input yall may be able to give.
