L275 Fuel Rack
Wooddoc
Tuscaloosa Al USA
The fuel rack is stuck on my L275. I took the cover off, sprayed PB Blaster inside and nudged it with a screwdriver but it will not move. Does anyone have other ideas? The tractor was sitting up for about 3 years. There is no fuel on the middle injector port but some on the first and third. Thanks for your advice.
I unstuck the fuel rack using a screwdriver and hammer. Just kept knocking forward and back. It slides easily now. There is some smoke coming out of the breather tube but tractor runs good now. I put some pump and injecter cleaner in the fuel tank and hope that will help. I used Seafoam. Lift is slow probably needs new fluid and filter.
