L2550 Starting Problem
scottz
1988 L2550DT-GST 2001 BX2200D HST 2016 L2501 HST
Nov 27, 2015
60
Colorado
I have a starting problem (electrical) with my L2550 that has been intermittent for quite a while. The tractor will go for months with no problem, then start acting up again. When I try to start it, I just hear the starter solenoid (loud click). Sometimes, if I try repeatedly, it will eventually start. Not today, so I jumped 12V from the battery to the starter control terminal and she started right up.
Here is what I have done so far:
  • New starter about a year ago
  • New battery Oct 2020
  • New ignition switch last week
It started just fine for several times after I replaced the switch, then today it did not start.
I think the clutch safety switch is working properly; if I depress the clutch, I get the loud solenoid click; if I do not depress the clutch, no click.
I am not aware of any other safety lockouts; are there any besides the clutch pedal?
I think my next steps are:
  • Replace the clutch pedal switch
  • Dig into the wiring between the ignition switch and starter looking for problem (it always starts if I jump 12V to the starter control terminal).
However, I'm confused since the starter seems to be trying to engage.
Any other ideas before I pull what hair I have left out?
Thanks
3,512
Next time you experience only a “click”.... see what the actual voltage is on the starter-solenoid-terminal. If less than 12V.... it’s likely either a bad terminal or failing start relay.
scottz
Nov 27, 2015
60
Colorado
Good idea, I'm thinking wiring issue or bad/loose terminal at the starter. Be nice if it was that simple. I was under the impression this unit did not have a starter relay. I thought the ignition switch did it all.
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
672
281
Herald Calif.
You don’t have a starter relay. If you add one near the stater I think it will solve you Problem. Chances are you are getping low voltage to the starter solenoid. I use a Ford type starter solenoid from Napa auto part. It will operate on low voltage.
Good Luck
scottz
Nov 27, 2015
60
Colorado
Good Luck
Now that is a great idea! Thanks.
rbargeron
Jul 6, 2015
1,181
258
western ma
Sounds to me like worn contacts inside the starter solenoid - take a look at this video.
The new contacts are available at many car parts stores or on eBay for cheap. Do it yourself and save a lot. Have fun - Dick B
rbargeron
Jul 6, 2015
1,181
258
western ma
Oops! - just re-read your first post and saw the starter was replaced a year ago. So my post above may be bogus. You DO have a solenoid, you could check and clean the contacts but they usually last several years. Dick B.
