Hey, new here - I could not find a prior thread on this specific topic/problem so forgive me if it has been addressed before.
Here is my problem -
2 weeks ago I went to start my L2550, it fired right up (like it always does) but then revved all the way up. I tried pulling the kill lever but nothing happened. Then the engine speed slowly dropped till it shut off. Now, it won't start.
Following the fuel lines I first replaced the fuel filter, the old one was a bit past needing to be replaced. Checked that fuel was getting to the transfer pump fine. No fuel was coming out of the t-fer pump, so I got a new one and replaced it.
Now I have fuel coming out of the t-fer pump quite well. Still not starting though... To make a long troubleshooting story short - I pulled the hard-lines coming from the injector pump to the injectors. There is no fuel being pumped out of the injector pump, at the most very very tiny spits even at full throttle.
I find it hard to believe that both pumps went out at the same time and am hoping that I am missing something here but at this time it looks like the injector pump may be bad as well. Is there anything I missed? Some crazy bleed/prime trick?
Thanks in advance for words of sage advice.
