L2501 owners, What RPM's do you run?
mckenzie913
12
Tennessee
What RPM's do you run when moving dirt with the fel, or using a box blade. I tend to use around 2,000 RPM's, but that may be due to the PTO engine speed (I'm not using PTO). I'm just looking to see what my fellow L2501 owners do. Thanks.
Poohbear
Jul 6, 2018
501
154
Gilmer,Tx,United States
I started yesterday moving dirt with my new to me L3301 & seems like mine likes 2200.
Mainah
L2501HST, BLMX3164 blower, BB1266 box blade, BX42S chipper, Titan forks
Feb 26, 2018
100
Standish, Maine
I usually run around 2k, sometimes 1500 if it’s just light work.
troverman
Jun 9, 2015
1,188
275
NH
I don't have a 2501 but I have a B2920, L4310, and MX4800. My B2920 has a a D1305 1.3L engine fairly similar to the one in the L2501. It has about 500 hours on it, and most of those hours are at wide-open throttle. Aside from increased noise and fuel consumption, don't worry about running at high RPM all the time.
markbxr400
L3901, LA525, RC1860, SCR0660, BB1260
May 19, 2018
56
Magnolia Springs, aL
L3901 - I pretty much always run everything at PTO speed. I have the HST transmission, and this seems to give me good speed control, etc. Also, DPF regens seem to come off without a hitch, without my having to interact at all.
Would be interesting to see a dyno chart to see where max horsepower/torque is developed. Did a quick internet search, but didn't turn up anything.
NewtoOrange
L2501
Mar 1, 2017
50
Pleasant Plains, Il. USA
Depends on how heavy I am loading the bucket. Usually I load bucket in Low gear then depending on how heavy and how far I am going to unload I may use Medium gear or even High if load is light so my rpm's vary between 1500-2000. However, being old school I also tend to "listen" to what the engine is telling me and make adjustments.
NYOrange
Kubota L2501hst
Mar 23, 2018
20
Western NY
Haven’t moved much dirt yet but using the bb and everything else I’ve done so far I’ve run at pto speed or just under.
Dunebug64
L2501
May 4, 2018
Lugoff SC
my dealer said to run full throttle ,,,, it is better than lugging the hydo. pump ....and if you start loosing power back off the go pedal ... you will have more pulling power and will not stall out ....
Shadetree03
L2501, King Kutter, Landscape Rake, Titan 3pt forks
Sep 20, 2017
115
12
Pueblo, CO
wide open (2200) on hi range...except when pulling into the carport :)
jus kiddin... usually around 16-1800 with ground speed depending on task; probably should run it a little higher like Dunebug said
Smokeless
3901/Loader/Rear Blade/Box Blade/LP Mower/Pallet forks IH M,,Cub & sickle mower
Feb 5, 2018
237
9
Southern Illinois
3901 hst, warm up 1500/1600.
Operating 2100
Mowing with finish mower 2500
56 hours, so far two regens. First one probably due to dealer puttering around shop.
Beaudeane
MX5800, LA1065, BH92, BB72X, RT72.40, EA 60 in grapple, county line auger
Mar 9, 2018
128
Dalton, Ga
Different tractor but I always run in the pto speed. No issues so far and hope it keeps down any dpf problems
