I have a question about the rated lift capacity (at the 3 pt hitch) for a L2501. According to the Kubota website the 3point will lift a little over 1900lbs at 24". Ok that sounds great but then I noticed the 3301 & 3901 is rated at a little over 1400lbs at 24". I have always understood that the L3301 & 3901 as basically the same tractor as the L2501 with more power (33hp & 39hp). If that is the case why is the 3pt lift capacity considerably less than the 25hp L2501? Is this a misprint on the Kubota website and literature or some mechanical difference I am unaware of, just curious.
