L2500 Overheating
wbledbett
L2500
Jul 16, 2015
lebanon, mo
I have an L2500 that will only overheat if running the PTo and the outside air temp is 70 degrees or higher. It will overheat in about 20-25 Minutes. If it 50-60 degrees you can work all day and it not over heat. Never has got to the point of boiling over. Any suggestions? I have owned it since it was new.
1970cs
1,124
Grand Ledge
Hours on the machine? What implement are you running on the PTO? Is this something that's been happening or is this a new issue? When is the last time you cleaned the radiator net? Have you blown compressed air through the radiator fins? Have you tried to rinse the radiator fins with a garden hose. What does the core interior of the radiator look like?
Pat
Tooljunkie
May 13, 2014
4,150
I dont believe its an overheating problem, but a heat dissipation problem. Exactly as above.
Would like to add,belt tension correct also.
