L2500 3point hitch not working
Kubota chad
L2500
Mar 22, 2026
Ontario
Got a 2001 L2500 that the 3 point hitch as stopped working on it i could notice it was starting to lose height when my snowblower was pined up getting lower and lower to the ground with my lever all the way up and then few days ago while snowblowing it didn’t want to raise at all anymore.. as anuone with the same tractor have the same issues
10,315
Hydraulic oil level low or Feedback linkage has come loose or out of adjustment.
Kubota chad
L2500
Mar 22, 2026
Ontario
Does it use the same oil as i put in the transmission or does the 3 point unit use oil from elsewhere cause my transmission is half on my sight glass
whitetiger
Nov 20, 2011
3,439
1,880
Kansas City, KS
It uses the same oil reservoir for both.
Did you check your feedback linkage as suggested by North Idaho Wolfman?
