L2500 2WD front end lube ...
tdwinklr
L2500
Jul 27, 2022
TX
The manual keeps saying there is a place to lube the front axle pivot on this tractor.
It is NOT 4WD but rather is 2WD, yet there isn't a Zerk fitting anywhere on the pivot itself.
Anyone out there know for sure where to lube this, or is it sealed?
thank you
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
2,955
1,622
WestTn/NoMs
thank you
I don't have access to an L2500 manual, but the construction seems to be the same as the L2501. The Op Man indicates that there's a zerk on each support, front and back. Is there a zerk or an opening to install zerks? The parts diagram shows a plugged opening on the back end of the support shaft. Maybe it's drilled and cross drilled to lube both support bushings from one point?
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
2,955
1,622
WestTn/NoMs
I can't see or feel anything at those points, and I've looked several times.
How about back here? Pull that plug and stick a wire in there to see if it's drilled to the front bushing. I'd be inclined to slowly pump a little in there and see where it comes out. Take it easy, there may be seals.
