L245DT what to run in trans.- hyd. system
jimg1955
L245DT
Apr 1, 2020
canton
according to my manual-trans SAE 80.being that this is also the hyd.sump.never heard of running 80 weight in a hydraulic system.i have the kubota operator and workshop manuals.nothing in the hydraulic section on fluid.going over a tractor that sat for years,checked all levels and condition,got it running and moving.while im at it if you are reading this you probably own a L245DL best place for tires and wheels.
1,446
You can use Kubota UDT or other universal tractor fluid in it.
Be sure to take the plugs out on the rear axle housing . There may be two per side.
jimg1955
L245DT
Apr 1, 2020
canton
thanks for the reply.i am new to kubota but have worked on everything from lotus to link-belt over 50 years.the manual is pretty slim on lube specs ,found this place and figured i would ask.
6,619
UDT is the replacement for the SAE 80
I use Mystik JT-5, it works excellent.
I've used it for many a year!
shootem604
Apr 23, 2018
875
British Columbia
I used Tractor Supply Co's Traveller Premium tractor hydraulic and transmission fluid. It works fine.
3,323
according to my manual-trans SAE 80.being that this is also the hyd.sump.never heard of running 80 weight in a hydraulic system.i ......
Every 9N/8N Ford or early Massey-Ferguson made... ;)
