L245DT Question
VegasDan
L245DT
May 6, 2012
Las Vegas, NV
By shear luck I found this site and just now registered.
I have a 1980 25 HP L245DT with a front-end loader with about 900 hours on it. I have owned it for 20 years, use it for dragging a horse arena and minor items. It has been a GREAT tractor! I maintain it regularly (I do the minor stuff and if I can't do it, as a last resort, I take it to a shop that works on Kubota's to do the major items - only brought it in once).
Problem: There appears to be a strain on the hydraulic gear pump, because when I drop the bucket down, the engine runs better (has a boost of power). That lasts for about 4 seconds and then it bogs down again. This strain causes the hydraulic fluid to overheat (anything that has the fluid in it gets super hot). Plus the engine eventually overheats and I have to then cool it off. Does anyone out there know what might cause this problem? Thank you!
WinnieCouple
L245DT, razor brush hog, small disc, double bottom plow, 5' Turfline Box Blade.
Aug 1, 2011
117
Hico, Texas
when was the last time you changed the hyd filter screen...?
sounds like you may have some flow issues
birddogger
433
Pittsburgh
Check for pinched or kinked high-pressure side pipes and hoses.
I've heard stories that the flexible hose can de-laminate inside, the pressure will the get between the laminations and squeeze the inner one closed. You could try; shut it off, lower bucket and work the levers to release any pressure then squeeze the hoses down their length in several places, if you feel a softer spot(s) that hose could have this problem.
I'd also take a close look through the whole coolant system, it should not be over-heating just becuz the motor is working a bit more; what if you were dragging a plow through 60 acres? it should over-heat?
MikeL
L185F L245DT L1200 L1700 L235 L4530B
Aug 29, 2012
54
Falls, PA
If you have the L1200/1700 loader with the standard control, check that the pressure relief valve on the control is not clogged. As with the previous post most of the issues I have had with my 245 hydraulics have been screen related.
__________________________________________________________________________
I do not always drive tractors, but when I do I prefer to drive Kubota. Stay Orange my friends,
