Well folks this Kubota is starting to be like a boat. As soon as one problem is fixed and diagnosed another one appears. I have a leak that I cannot locate the source. I started to remove the front axle thinking the seals in between the pinion gear and coupling were bad. As I was struggling to remove the tie rod I realized the oil was leaking down from a open hole in the front axle bracket. This hole is higher than the top part of the axle and seal. I checked the parts book and nothing jumped out at me. There is no oil in front of the motor that I can see. I am at a loss as to what to pull next. I have attached a few photos for reference
![ImageUploadedByTapatalk1348014812.229990.jpg ImageUploadedByTapatalk1348014812.229990.jpg](https://www.orangetractortalks.com/forums/data/attachments/5/5330-01cdf81dc89fa1d2aa5e32bec790d52e.jpg)
![ImageUploadedByTapatalk1348014777.797781.jpg ImageUploadedByTapatalk1348014777.797781.jpg](https://www.orangetractortalks.com/forums/data/attachments/5/5328-42911d6c35479eb91c5c509459f8908c.jpg)
![ImageUploadedByTapatalk1348014797.856598.jpg ImageUploadedByTapatalk1348014797.856598.jpg](https://www.orangetractortalks.com/forums/data/attachments/5/5329-7c380b57742643beec6f780c4ca92fa7.jpg)
