L245DT Hydralic line question
primernova
L245DT
Jan 20, 2018
Choctaw, Ok
L245dt, l1200 loader with two spool valve. Besides the hoses going to the rams, I have three hoses, two from an aluminum block mounted above the relieve valve (they appear to me to be the supply and return for the loader) and 1 hose that comes from the power beyond and runs back right next to the knob for the three point that sets 3 point speed. Does this sound correct and if so, why power beyond to that location? Does that feed the three point? Thanks
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
642
256
Herald Calif.
Hello
If you Tractor is the later L245DT with the aluminum block on the left side of the seat , then the front port on the block is the pressure or in to your loader valve. The rear port on the block should go to the power beyond on the loader valve. The return or out from the loader valve should dump back in to the transmission case normally in the center top under the seat.
Good luck Lance
