L245DT Hard Warm Start
9,219
WHOA....! Yes you do have low compression. Have you checked the valve clearances yet? You could have tight valves. Check the clearances first before diving in and pulling the engine down.
You do know the odds of that are about a billion to one right...:D
motorhead
2009 B3200, 2007 Dodge/Cummins powered Ram 2500 395hp
May 17, 2012
441
42
Atascadero
I am surprised you didn't mention checking the valve clearances. Found many Mercedes diesels that were hard starting, both cold and warm and they had tight valves. Found this on VW diesels too. Set them to proper clearances and the engines started well. He could well have worn rings too but why not at least check them for clearances.
ranger danger
Kubota M6060, MEB 802A tactically quiet generator
Jun 11, 2017
310
294
East of Placerville Ca
Thanks everyone, I do appreciate the help. I've been reading and watching youtube videos. I'm going to do the work myself. My plan is to pull the head and check the bores, valves and head condition. Then I'll make some decisions on how far I need to go. If needed, I'll put in new sleeves, pistons, rings and rod bearings. I'll also reset the valves when I put it back together.
From what I have been reading in the parts catalogs, the sleeves come "Semi Finished"??? Does that mean I still need to hone them before installing the new pistons? For removing the old sleeves, does this video look right?
https://www.youtube.com/watch?v=gwrNE9S6e_8&t=19s
