I had the tank on my L245Dt project tractor cleaned and coated internally, unfortunately the tank drain was there when the tank went to the shop and missing when my wife picked it up (and I did not get back in for a while as I was working away).
Long story short they have lost the tank drain and I can't figure out what the internal thread size is.
Not sure if it was a originally a plug or a drain valve.
Seems to be a fine tapered thread about 9 mm in diameter but dos not match any of the "normal" thread sizes I can find.
Does anyone have any idea on the thread size or have a plug they could measure for me (or a scrap tank with the drain I could buy)?
Otherwise I will have to drill it out and fit a larger plug then clean the tank again!.
Thanks
Simon
Thanks
Simon
