L245DT 4x4 lever
RobHenry
L245DT
Mar 27, 2020
Llagrange ky
Help. I'm new to kubota. I took the 4wd engage lever off to replace the oring. Now it won't go back in the correct location. It seems to have rotated itself backwards into the 4x4 location and won't move forward so I can reinstall the bolt.
6,627
Easy fix, drain the hydraulic fluid and pull the case, assemble it, then reinstall the case.
But before you do that, pull the shaft outward and try turning it.
