Anybody have a suggestion?
I changed the transmission oil in my L245 this weekend.
8:00 started tractor (all worked as usual)
8:20 turned off tractor; drained oil from two ports and final drives
8:40 removed filter screen; replaced it and o-ring
9:00 tightened all plugs, pulled pan out of way
9:15 began filling with universal tractor transmission fluid (TSC Travellers ~ UDT)
9:30 begins to flow from oil level port (LH side); ~ 23 qts
9:45 attempt to start tractor
It took several attempts to start, and really had to lean on the glow plugs. Finally it started and acted really burdened, almost like a flooded gas engine. Also noticed the hydraulic pump has a subtle high pitch whine and the 3-point does not work. Ugh. Anybody have an idea?
