L2350 tie rod end torque specs??
greagin
L4200DT-GST
Apr 4, 2016
31
SC
Anyone got torque specs for tie rod ends on a L2350DT? Also, one tie rod end has a castellated nut, one does not and the ends are a little different?? Is that correct?? Torque specs would be much appreciated if anyone has them! Thanks in advance!!
9,782
Sounds like someone has replaced an end with a cheap after market one.
The Torque is 36.2 to 50.6 Ft lbs
greagin
L4200DT-GST
Apr 4, 2016
31
SC
Yes that's heat I'm afraid of.... I guess it's off to the dealer time for the left hand one. The right hand one from A&I seems very legit. But the left hand one is pathetic.
Tooljunkie
May 13, 2014
4,150
34
Some manufacturers use a nylon lock nut instead of a castle nut. Good enough for 4000 lb cars hurtling down highway should be good enough for tractor. If i had the option, would be castle nut as it seems to thread up easier and a better feel for tightening.
