L2350 Open/Close Hydrolic Control Valve Stuck
Tennesse Kubota
L2350
Aug 8, 2010
Madison, Tennessee
I have a late '90s model L2350. When lowering the control lever for the 3-point hitch it was moving too rapidly so I began opening the control valve located just under the seat. I opened it about 2-3 turns and now I can not budge it (the control valve) or turn at all. It won't turn right or left -- open or close. And now the 3-point hitch is "stuck" in the up position. Everything was fine until I "opened the control valve."
I started to remove the valve assembly this morning and it felt as though, as I loosened the bolts, that the entire assembly is under pressure, therefore I did not take it out.
Help please???
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
78
Rocky Face, Georgia
Have you tried spraying some good penatrating oil on the shaft of the valve to see if it will loosen it up?
