l2250 won't move (clutch is fine)
goatiemon
l2250d with a bf400g loader and bl4690a hoe
Mar 20, 2026
9
11
santa cruz
good day
thanks in advance fer yer help
I'm a decent shade tree mechanic, but new to tractors
tldr: tractor won't drive (dual clutch)(mechanical transmission) clutch is in spec, transmission main shaft spins freely - even in gear
please help
here's the story:
parked it fer lunch
adjusted the free play in the clutch pedal
(was super slack)
after lunch
PTO engages
but the tractor won't drive
it's got a dual stage clutch
and l figured it was stuck engaged ..
so l split the tractor
removed the clutch
there was some rust
so sanded rust, applied anti-seze
adjusted to spec
put it back together;
same problem :(
split it again
no matter what gear, or direction (F/R)
is selected
for what is worth, it feels like it goes into gear
so it seems to me like a transmission problem?
when l drained the oil it was clean, (no metal chunks)
please help
thanks
goat
JasonW
868
583
Al
Does that model have a high low range selector? It could be in neutral.
goatiemon
Mar 20, 2026
9
11
santa cruz
found the high low selector
didn't know it had one...
(lable is missing)
and that seems to be the problem
thanks!
guess l should have posted here first
and saved myself a lot of trouble
oh well
one way to learn
11,143
How did you determine the main shaft is spinning?
Main suspect is range lever not engaged.
Can you engage and disengage the PTO?
Do you have the WSM (aka service manual)?
goatiemon
Mar 20, 2026
9
11
santa cruz
l have the manual
spun the shaft by hand
(after splitting the tractor)
yes it was the range selector
l didn't know it existed....
lot of work
little reward
oh well
thanks
11,143
So we are all back up and running?
goatiemon
Mar 20, 2026
9
11
santa cruz
got it back to gether Friday evening
testing it today
and now the clutch is stuck disengaged!
stomp on the pedal and tractor still moves/gears grind
adjust the pedal linkage till no free play at all (book says about an inch)
still no clutching
wtf!
l did adjust the main disk adjuster screws
(to spec, with a feeler gauge)
did not adjust the first set of adjuster screws
seems like l over did it?
unfortunately the inspection cover is under the loader attachment...
which l was hoping not to remove
but seems like l need to
try to see what is going on in there/adjust those screws....
really don't want to split this thing again
thoughts?
goatiemon
Mar 20, 2026
9
11
santa cruz
got the inspection cover off
easier than l thought
looks like the friction disk isn't sliding on the input shaft...
looks like plenty of release...
(more than a 1/16th of gap)
seems like l get to split it again
if the hydraulics were connected
I'd be tempted to drive it around
brake hard with the clutch in
see if l can get it to let go
but
they aren't
so
guess Imma split it again
unless someone has a better idea
goatiemon
Mar 20, 2026
9
11
santa cruz
it's apart (again)
turns out (rushing) on Friday l broke the PTO clutch friction disk
and got the center section jammed in the clutch housing
that's what l get
l guess
any way
waiting on parts now
pigdoc
G1800S L2500
Aug 19, 2022
403
350
SE Pennsylvania
Ya, when I read the message subject, my first thought was the Hi-Lo lever. Dang, too bad you went through all that unnecessary work.
My L2500 has the same lever, on the L side of the trans. On my tractor, starting circuit is not energized unless that lever is in neutral. The mechanism where the switch is at the back of the lever was a bit fussy, so I doused it good with PJ-1 and it works great now.
-Paul
goatiemon
Mar 20, 2026
9
11
santa cruz
finally got it all back together and working
as it should
turns out that the PTO part of the clutch wasn't working
want really an issue before
but now it's working
(just trying to console myself ;)...)
thanks for the help
