L2250 electrical issues
bunz
L2250, mower, tiller
Mar 19, 2012
HMB, CA
Greetings, I'm new to the board and a new owner of a 'Bota L2250. Machine is in good running shape, but I have some interesting things goin on with the electrical.
Previous owner must have had some issues as well, so that may complicate things (I see a few wires that have some nicks in the casing that have been covered with electrical tape).
So, the machine starts without a key. Fires right up w/ push button. (why?)
When we were transporting it home, (naively) the battery slid around and the positive cable came in touch with the frame. We have no dashboard lights/gauges. The RPM meter DOES work, although it was disconnected and I had to re-connect the wire in to the gauge board.
I have followed all wires around as best I can and looked for any damaged wiring, but I am new to this machine. Like I said above, there are a couple spots on wires that have been taped, but all looks respectable.
Where do I start to look for what may have fried? I do have a good electrical tester, tools and time , so any help would be appreciated!!
bruceatlam
B20, FEL, box blade, flail mower
Aug 20, 2009
410
Camarillo, California
Did you find any fuses? Look around the lower left side of the dash. You should have some somewhere --- I don't own that tractor so can't help a lot. I would think you blew a fuse.
lreops
L3400DT W/ LA463 FEL and L235DT W/ BF400 Loader
Dec 26, 2011
306
Rising Sun, Maryland
I'd add using a Test Light and start tracing what power you do have and where you don't.
Ron
bunz
Mar 19, 2012
HMB, CA
Thanks guys. I'm going to have a look tomorrow at where I'm losing power...
I did of course check fuses, should have mentioned that :)
