L2201DT tires & Rims
Foxfire
L2201DT
Apr 16, 2011
Chittenden Vt USA
Just found myself with a L2201DT with 22.5 truck tires on turf rims. half decent turf tires on front. I'm torn between just chaining the rears and running it to see what what other surprises I find (I already found a burned up Electrical system, and the front end full of grease), or just biting the bullet and springing for Ag tires and rims all the way around. She's narrow enough already, and those truck tires really make me nervous. Is there such a thing as a list of tires and rims that fit this beasty? I heard most any thing for an L series will fit.. but so far, the only thing that gives me hope is the motor.. though I did find fresh wrench rash on the valve cover bolts and the injector pump..
meanjean
Kubota MX4700
Aug 10, 2010
922
Hazelridge, Manitoba
Where are you using your tractor?
Maybe the currents tires are fine.
AG tires might run you $300 a piece.
You could probably source some meaty used truck tires for half that.
