L175 Transmission Reverse Gear/Input shaft question
PYC Tractor
L175
Sep 12, 2012
mandeville, Louisiana
Split the tractor and changed the clutch. Not too bad a job. Got it all back together and fired it up only to find the famed Reverse Gear problem! So I pulled the reverse gear from the top without splitting the transmission front and back.
Question- The gears on the input shaft look a lot like the revers gear stripped on the edges! Is that typical with the reverse gear problem? Is it essential to change the input shaft as well?
That will surly require the transmission removal.
