mwood1129 New member Equipment Kubota l175 Nov 28, 2021 28 0 1 Usa Sep 19, 2022 #1 What is the hour interval for changing transmission oil for my L175 ? thanks
Roadworthy Well-known member Lifetime Member Equipment L2501 HST Aug 17, 2019 1,649 526 113 Benton City, WA Sep 19, 2022 #2 It's old enough you may not be able to get an owner's manual. If you just got the tractor it would probably be wise to change all fluids and filters. Beyond that, I think my L2501 wants transmission oil changed at 400 hours.
R Russell King Well-known member Lifetime Member Equipment L185F, Modern Ag Competitor 4’ shredder, Rhino tiller, rear dirt scoop Jun 17, 2012 5,371 1,418 113 Austin, Texas Sep 19, 2022 #3 Every 300 hours First one was supposed to be done at 50 then 350, 650... if you’re really trying to follow the rules
Torinodan Active member Equipment T1600, G4200, G5200, Ford 2810, 1974 Wheel Horse C100 Oct 14, 2021 199 94 28 Fayetteville GA Sep 19, 2022 #4 Change whenever it gets water in it from around the shifter seals leaking. If you store outside without the shifters covered.
