D dmalquist New member Equipment kubota l1500dt Aug 18, 2021 5 0 1 PAHRUMP, NV Jun 6, 2023 #1 Not a diesel mechanic. Going to remove injector pump. Anything I should be aware of in removing?
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 31,067 7,026 113 Sandpoint, ID Jun 6, 2023 #2 The rack will need to move to get it out a notch in the block.
R Russell King Well-known member Lifetime Member Equipment L185F, Modern Ag Competitor 4’ shredder, Rhino tiller, rear dirt scoop Jun 17, 2012 5,504 1,495 113 Austin, Texas Jun 6, 2023 #3 There may be some shims between the block and the pump that must be kept up with and used again when replacing the pump. Little springs will be involved so use finesse and don’t damage them or let them fly to freedom. Reactions: 1 user
