l1500 coolant issue
coachhunt77
nashville, tn
I replaced the nipple/filler plate where the coolant enters the engine from the radiator and now when I pour coolant/water into the radiator to fill it, it runs right out the back of the engine through this large hole that is about 1-1.5 inches in diameter. What does this mean?
Kytim
Aug 14, 2009
848
Western Ky
Yep, sounds like Gordon is right but, why did you need to replace the water neck? was there some other problem?
coachhunt77
nashville, tn
Yes, the waterneck actually had been broken and repaired when I bought it but the weld didn't hold and it finally broke all the way off. It was a bear to put the new one on but I finally got it. Thanks guys.
