Hi I m new here and have had some problems with my l48. I had a wood spliter hooked up and split a few cord s with no problems as I had last year. The way I have it set up is using the backhoe I hook up my lines to the 2 lines that come out of the right rear of the tractor. I do this so that I can leave the hoe on the tractor while I split my wood. Easier than trying to get to the quick connects with the the hoe on. Anyways after splitting wood and hooking the hoses back up for the hoe. It doesent lift the loader or the hoe at idle. I have to rev the engine up to get it to lift. The curl functions work fine at idle and the hidrostat works fine as well. Seems like the power steering is not as great as well. I ve changed the filters as well as tryed everything I could find on the net. I took the pump shaft out today to see if the coupling was striped but the splins look great. Haven't done a flow test or pressure test because I don't have the equipment. I wondered if anyone has any ideas of what could cause the change in the tractor. It s not the first time I ve had the splitter on. Any help would be great. Thanks a lot
