T Tn1977 New member Mar 1, 2013 31 0 0 Waverly,Tn Sep 18, 2014 #1 Does anyone know if there is a relief port on rear grease fitting on front axle? I'm also curious as to how y'all check hst level as far as orientation of front loader and 3 point hitch. l 3800 Hst Thanks
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 30,212 6,384 113 Sandpoint, ID Sep 18, 2014 #2 Yes there is a plug opposite the grease zerk. The loader should be on the ground, and the three point raised.
B Bluegill New member Equipment L3750DT Shuttle, L3800DT FEL both Jan 11, 2012 1,560 4 0 Success Missouri Sep 19, 2014 #3 There is no relief port (plug) for the grease zerk on the 'rear' pivot point on the front axle. But there is one on the front pivot point.
