L-35, R&R Key-Stop Relay Timer
K7KY
Kubota L-35, cultivator, box scraper, 12", 18", 36" b/h buckest
Jun 22, 2020
15
SW/OR
I'm having trouble accessing the Key-Stop relay. I can't get the instrument cluster out. It's attached to the Tach drive, I think. I'm not certain where this relay is; I think it's in the cowling under the instruments. If you've replaced this relay, I'd appreciate some idea of how to reach it. TIA
9,667
It's here (pic)
There is 4 bolts that hold the display in.
K7KY
Jun 22, 2020
15
SW/OR
Thank you, Wolfman
K7KY
Jun 22, 2020
15
SW/OR
The tach cable is pretty short. Reach back there with pliers. Once you get that off there should be lots of room. Tilt the steering back all the way first.
PoTreeBoy... Thank you so much! That's the final piece of info I need. I'm a bit disabled and only work a few minutes at a time. With the diagram and the instrument panel removed, I should be good to go. It's easy to forget the key when stopping with the fuel pull knob. This happened to my wife resulting in next day no-start.
