L 3000 Air Filter Upgrade
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
78
Rocky Face, Georgia
Just got thru watching Service Dept Vic on You Tube (Servicing 101)and it made me think about this.
This is something I think is worth every penny spent. Everybody who has serviced a L 3000 tractor has seen the single air filter element. How many times have you wanted more protection and easier service? Many of us are familiar with the much better dual element radial seal type filters that come standard on the higher priced line of the L series tractors. If you are like me your dealer didn't tell you that a dual element filter system is offer for the L 3000 model. It is a direct bolt on part that requires no type of modification and comes with everything needed to install. Simply unbolt and remove your single element filter box and install the new dual element radial seal system. With this part in place you will have a inner filter that takes the worry of dirt getting passed your single filter and the added benefit of a radial seal as well. Not only will you have better engine protection but make it easier on you to maintain.
If this interests you contact your local dealer:
Part number: 32330 - 98401
Part name: L 8349 Double Element Air Cleaner
