l-295 model 3 points not operating
victofreak
victoriaville
Can someone help me finding the solution for my 3 points not lifting, The pump operates the oïl exits and the bucket but do not lift the 3 points arms
thanks
5,517
Have you messed with the knob under the seat?
Does it have draft control?
Look for control or feed back rods off of the 3 point that go back to the valves that might have become disconnected or loose and out of adjustment.
victofreak
victoriaville
Thanks for your prompt answer,
the knob Under the seat is for adjusting the speed of the drop on the 3 point,
my controls are electric on that model, .
I lost the oïl in the case , ,I did refill the reservoir at the proper level , I got the tractor running , I bleed the trans oïl pump,
but I have no oïl pressure for the 3 points
5,517
Trans pump?
Are you talking the hydraulic pump?
How did you loose hydraulic fluid in the first place?
How long did it run like that?
Did you change filter when you did fluid?
victofreak
victoriaville
Hi I opened the trans cover to find that the 3 points went to low ( I had a wood chipper attached and the wood chipper was much lower than the rear wheels of the tractor . Then the amrs went to low and the piston connector cracked the cylinder in the transmission cover and some metal pinched the piston and now , the piston is stucked in the top position.
I am looking for a used transmission cover to replace that one ,
My model is:Kubota Sunshine ZL-295,
4wd,
thanks everyones
