L-185 f front tires
Diydave
L2202 tractor, L185f tractor
Oct 31, 2013
1,635
11
Gambrills, MD USA
Mine has turf tires front and rear. Looking to see if anyone knows whether any car rims will interchange with the fronts, want to go to a narrower front tire, for easier and less slip steering. Don't care if it raises the front axle height, a little.
MadMax31
BX23S, 60" MMM
Nov 5, 2014
766
New York
I think some guys are running trailer tires as a replacement. 1760 lb load rating? The overall diameter was pretty close and narrower as you want as well. My front turfs are on their way out. Sidewall is coming off in chunks from dry rot.
ShaunRH
L3200
May 14, 2014
1,414
Atascadero, CA
If you know the bolt circle and the Rolling Circumference, you can usually find a set of rims and tires to work with it.
