l 1501 [l 185]
1,418
Are you sure it is fuel?
My l185 was having trouble with increasing engine oil level. That was caused by a bad seal on the hydraulic pump shaft.
Repaired that and problem solved.
I had to order all of the seal variations (3 or 4 different part numbers) to get correct seal. I assume the pump was replaced and no longer matched the tractor serial number for the correct part. They were inexpensive enough to not be too concerned with ordering them.
If it is diesel fuel then I would suspect a seal leak in the injection pump but I am not sure that model tractor has that problem seal.
Others will be along to comment on the problem soon
mickeyd
Mar 21, 2014
1,192
Guin, AL
Welcome to the OTT forum. :)
Does the oil smell like diesel fuel and that is why you suspect that it is leaking?
