KX91-3 Drive levers don't move
WisconsinMinnesotan
KX91-3 S2
Dec 7, 2024
Balsom Lake, WI
Hi, I have a KX91-3 S2 mini. The drive levers don't move are locked by a bracket under the platform that toggles up and restricts movement. With both lock levers down, everything else works (swivel plus all boom /bucket/blade movements). I can operate the tracks if I disconnect the linkage from the drive levers. What controls that lock bracket at the bottom of the drive levers and what can I do to fix? Thank you very much!
6,594
It looks to be a hydraulic lock and it also looks to be feed or controlled by the swing motor.
The WSM (aka service manual) would cover how to test and fix it.
