KubotaL2550 bucket hydraulic issue
JdanL2550
Kubota L2550 with an LA400 loader, cannon box scraper, and a auger attachement
Nov 29, 2020
Northern California
I’ve just replaced two hydraulic lines and replaced hydraulic fluid, but prior to this, and now still an issue I’ve noticed that when I try to lower the bucket there seems to be an issue. I push it forward ( to lower the bucket) and it initially starts going up and then very slowly lowers and it feels like something is stopping the lever from fully going forward. I can push it further forward and the bucket lowers quickly but it feels like something is catching in the lever mechanism. It also seems to be very under powered when using the bucket to lift anything. Any ideas?
Roadworthy
L2501 HST
Aug 17, 2019
1,647
526
Benton City, WA
Your description sounds as though when you hit resistance you may be going into float mode on the control which is a non pressurized mode where gravity is allowed to pull the bucket down. As far as the strange reactions to the controls, make sure you have no leaks on the connectors where they hydraulic lines were replaced. A leak in the system can cause the symptoms you describe.
JdanL2550
Nov 29, 2020
Northern California
Thank you. I was pretty thorough checking for leaks initially after replacing the lines, but I might have missed something so I’ll be sure to double check
whitetiger
Nov 20, 2011
3,072
1,515
Kansas City, KS
Check the hoses to see that you did not cross them and that they are plugged into the correct coupler. Check to see that the couplers are fulled latched also.
