Kubota2380 mower deck stuck in up position
Pkailing
Kubota BX2380
Dec 19, 2024
Oregon
I recently had my 2380 tractor serviced. When the tractor was returned to me the mower deck won’t lower. It is stuck in the up position. I can hear the hydraulics trying to work when I move the lever, but the deck does not move. Any ideas?
Tractor Gal
BX23D MLB
Oct 30, 2020
628
278
NC
Sorry for the silly question, but have you checked the deck height knob that is just below the seat? If that is in the highest position, that position locks it into place. That thing can be persnickety and will insist on being difficult to disengage. And, you won't be able to look under to see since the mower deck will be in the way.
The other thing that came to me is that the lift arms are somehow "hung up" on something.
Be advised, Pkailing, that I readily admit to my limited knowledge but when I saw that no one had responded to you, I felt compelled. Who knows...one of these days I'll get something right! :)
Hope you get it figured out.
Tractor Gal
JimDeL
BX2380; 54" MMM; FEL w Pirahna bar; Ballast Box; BXpanded skid plate.
Aug 31, 2022
499
588
NE Ohio
Tractor Gal
TG got it right. Make sure you have the deck raised fully before you try to move the knob.
If that's not the problem then the dealer may have bent something when they reinstalled the deck (kinda unlikely, though).
Meadowbank Kubota
BX1880 with an LA344s
Aug 23, 2021
25
21
Cornwall, PE
If it was not number 1, another thing to check is the knob by your right heel and see if who ever serviced the tractor may have closed it when transporting the tractor to prevent the deck from dropping while being transported. This knob controls how fast the 3 point hitch lowers, and locks it when transporting with implements on the back. The 3 point hitch and deck go up and down together.
