Kubota ZG327 no start
samcarpen
Kubota ZG327 Commercial Zero-turn with 27hp Kubota engine no start. Cranks. Will temporarily fire when misting fuel into air-cleaner. Blows 15amp main system fuse. Disconnected fuel pump and continues to blow fuse. Can't locate a wiring diagram. Parts dealer who is also a Kubota dealer is very little help. Suggestions would be appreciated. Thanks, Sam
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,140
139
Hardisty, Alberta
Hope this helps
6,384
First thing to do if you want to fix it yourself is get the WSM, it will have a wiring schematic in it and will give you troubleshooting info.
P/N 9Y111-01142
Note: There was a delay in my posting. :rolleyes:
Eserv,
Thanks for posting the schematic...But it's way to tiny to read. :eek: ;)
Can you repost a larger version for the OP? ;)
5,207
1,893
There's a fuel shutoff solenoid built into the carburetor. Could also be an issue there too. I have one in my shop currently-rats ate the wiring under the orange engine cover-which includes the shutoff solenoid, one wire shorted to ground. If the 15a fuse is failing, there is guaranteed a short to ground somewhere.
samcarpen
Thanks for your help. Was able to obtain a wiring diagram. Turned out that it was the fuel pump relay that was shorting out.
100 td
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
If you can substitute the diagram in the earlier post to a readable one, it may help someone else out down the track
