I just bought this machine this week. While inspecting everything, I noticed that the A/C was not blowing properly through the vents. I could only feel air coming from one vent; however it was very low pressure even when turned to high. The air coming out did feel cold.
The line did feel cold, but I could also feel the compressor kicking on and off. I suspected low Freon but did not see any gas bubble in the sight glass that would normally be present with this issue.
I’m going to try to clean the condensers and air filter tomorrow. Someone mentioned the in cabin air filter as well, but I cannot seem to find it.
My question is, has anyone else had this issue and found an easy fix?
The machine only has 327 hours and is still under warranty. But I’d rather fix it myself if possible before I spend the time to load it up and take it to the service department. Thanks for any help
