Kubota transaxle leaking oil
samcarpen
Kubota T1460 lawn tractor with Kawasaki engine. Leaking around axle shaft. Can I replace seals without splitting case? Hydro-static transaxle. Any help would be appreciated!
Thanks, Sam
5,207
1,893
IIRC you have to split the case to replace the oil seal. It also wouldn't surprise me to see the axle bearings worn out. They're not really bearings, bushings actually. At that point you have a decision to make. Fix it or replace it. Those are great mowers and that 40" deck will cut better than any other Kubota mower to date once it's leveled, but parts are getting harder to find for the old T60 series, unfortunately. I think that transaxle was made by Hydrogear but I can't remember.
