N Nbrown New member Aug 6, 2014 4 0 0 Plymouth, ct 06782 Aug 6, 2014 #1 Hi everyone. I have a t1600 with an rc44lt mowing deck. I need to replace the deck bearings. Can someone please advise me on the process? I have the deck off and ready to be worked on. Thanks in advance. Nate
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 30,552 6,600 113 Sandpoint, ID Aug 6, 2014 #2 Remove the shields, remove the pulleys, remove the spindles, remove the bearings, then reverse the process to put it back together.
Tooljunkie Well-known member Lifetime Member Equipment L1501,home built carry all, mini plow blade. May 13, 2014 4,150 33 48 60 Lac Du Bonnet, Manitoba,Canada Aug 6, 2014 #3 Yup, undo everything that doesent look like bearing until you find something that looks like bearing. North idaho wolfman has it pretty much covered, take a picture or two as you go, like belt routing and such.
N Nbrown New member Aug 6, 2014 4 0 0 Plymouth, ct 06782 Aug 8, 2014 #4 Thanks guys. Got the spindles separated from the deck. Any advice on removing the bearings from the housing?
