I have a SVL90-2 that I recently purchased. After running for 15 - 20 minutes at full throttle it threw a code E:9206. That code means exhaust temperature sensor (DOC Outlet). I contacted several dealers and was informed that this was likely due to a faulty sensor or wiring issue. From what i could see the wiring had been tampered with before so it appears that the previous owner had an issue too. I checked the wires going to the first sensor before the DPF filter back to where they meet up with the big harness and couldn't find anything out of order, so I went ahead and ordered a new sensor. Well I installed it today and now I get two codes. Also to complicate things the machine says it needs to regen and it tries but never completes. about 15 minutes into the regen i get the E:9206 code and at the same time I get code E:9002 which according to the manual means DPF is regenerated. All while these codes are displaying on the panel the machine is trying to regen and the yellow regen indicator is flashing. I tried to pause the regen to see if it would change anything and i get a red warning symbol on the dash and a new code E:9006 which is Requirement for DPF regeneration. Needless to say I am a bit puzzled. Is there any way a consumer can clear the codes from the ECM? anyone run into anything similar to this? thanks in advance for any help!
