Kubota RTV1100 (2011 or 2012) REPLACEMENT WINDOW NEEDED
sdbaxter
Kubota RTV1100
Dec 23, 2024
NW Arkansas
Hi All!
I am looking for a replacement window for my grandparents Kubota. It is a camo Kubota with the full cab. The right window (with sliding glass) was recently broken and the replacement part ( K7721-29824) is 1200.00! I did find that they used to have a solid pane window though that has now been discontinued which is considerably cheaper that I have been trying to locate. The part number is (K7711-29330 RH*) and I have checked with several dealerships, including Messick's, Coleman, Springdale Tractor Co and several others. I have also checked for scrapyards, only finding one possible match in CA.
Does anyone have any leads or advice? Thanks in advance!
Sam
Workerbee
Zd21
Mar 1, 2020
222
114
MN
Do you have any glass shops in your area? If so perhaps they could get a pattern and have one made for you. You might need to take the door in for them to measure.
