The Ford gold coolant was said to be one of the causes of all the 6.0L Powerstroke failures. It has been said that the silicates drop out of that coolant and that is what plugged the EGR and oil coolers, thus causing the flash boils that push out the head gaskets.I have had good success with Celcius coolant. Probably a canadian thing.
Universal coolant. I stock one coolant and it save a lot of hassle.
Mopar long life if not replaced after its life cycle will leave deposits eventually plugging rad.
Gm dexcool reacts with plastic components causing them to fail. And is not friendly with green coolant, will eventually turn to mud if mixed.
Ford Gold coolant has not created any issues that i am aware of.
Long life coolant and de-mineralized water will protect your cooling system the best.
Zerex G05 is a HOAT coolant. You are correct that it is the same as the Ford gold used in pre 2011 Fords. The newer Ford Orange is the same as DexCool, and I would not use it in a vehicle not specifically designed for it.The oat stuff I have is the zerex g05. It was called for in both the previous ford vehicles we owned.
sent from a field
eipo,Put my block heater in tonight and curious if anyone is running other than the green stuff? I have a bunch of OAT coolant from previous fords.....
I'm not doubting what you say, just confused on what to buy.eipo,
This spring I drained and flushed the cooling system on my BX2350. I put in the Rotella ELC (Red Propylene Glycol) and I notice that it runs about 15 degrees cooler under heavy mowing than it did with the green ethylene glycol from the factory. Just my 2 cents worth.
Dave
