Kubota MX5200 Hydraulics Questions
JMV
2015 MX5200 HST 4x4 FEL
Oct 16, 2017
Roxton, Texas
I am fairly new to Kubota even though I have had my MX5200 HST 4WD since new for over 2 years now; I always had Ford tractors prior to this one. I am looking at installing the Land Pride 380-166A 3rd Function kit to my LA1065 loader to be able to run a grapple; I am also looking at installing rear remotes at the same time for plows, a homemade log splitter, a Rhino 12' shredder, and any other hardware that requires rear hydraulics. My first question is with the 3rd Function kit am I limited to 2 rear remotes or can I still install all 3? My second question is for the rear remotes; can anyone confirm if these are the correct parts I need or if I missed something?
1st Rear Remote: L8303 valve / MX8451 mounting base/lever
2nd Rear Remote: L8304 float detent valve / MX8452 mounting base/lever
3rd Rear Remote: L8303 valve / MX8453 mounting base/lever
Mine already came with the MX5171 lever guide.
Thanks!
afret
L3901, MX5800, U55-4
May 7, 2015
167
North Idaho
I had the 3rd function and 3 rear remotes installed by the dealer when I bought my MX. I think the 3rd function is by Land Pride. I have one free remote and the other two are for my top and tilt. The free remote has the quick connect in the back and the two for the TNT don't have quick connects.
JMV
Oct 16, 2017
Roxton, Texas
Thanks 1970cs and afret; that makes me feel more comfortable in ordering this hardware; I had thought about TNT but didn't really consider it but it sounds like you have a nice setup.
Jfeco
Mx5200
Jul 8, 2018
11
Foley Mo
Does anyone have a manual to install the factory 1st remote? I have what kubota sent in the kit but it’s a little confusing. Also, if anyone has done this install do you have any pointers?
Mechanical Type
Mx5200 8' scrape, 7'Box, 6' hog, Grapple, forks
May 17, 2020
Country Living
Did this get everything you needed for a 2nd remote?
Levers, valves, hardware, hoses, etc?
My local dealer said this will get it.
He wanted $190 more than Messicks online. I don't get it. Why doesn't my local dealer want to be competitive?
