Kubota M7500 hydraulic problem
roger d gregory
Kubota M7500
Mar 23, 2019
COLEMAN, Texas
I just purchased a Kubota M7500 that runs and drives great. My problem is the 3-point lift is stuck or locked in the extreme up position. I just pulled and cleaned the hyd. filter and changed the fluid, no help. It looks like it is mechanically locked in the up position. It may be something simple, I need your help.
SidecarFlip
Banned
558
Should be. It's the 3 point metering valve (knob under seat) that needs released. probably stuck and needs lubricated with PBlaster and worked until it releases. Had that issue with my M9 a while ago. Wolfman steered me right to it.
9,121
The fall adjustment is the most likely, one other issue could be the feedback linkage has been messed with or damaged.
