Kubota M6040D cabin model
justahayin
M7040 M6040
Aug 25, 2021
Tennessee
I was checking to see if anyone could help me out, I bought a M6040 cab model and the radio and interior light was not working when I went to look at it. The guy said his mechanic couldn’t find where to look after the fuse box but he could jump the wires around in the fuse box and it would work. Is there another junction that I could check out? I tried to find a wiring diagram online that would show me but I couldn’t find one. Thanks
5,324
2,001
going off of memory. Before you climb into the tractor look above the clutch pedal for a fuse box. They're normally covered, so you won't see any fuses, but I think it's right there.
If not look under the hood, right side of engine kinda up high.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,251
1,032
Williamstown Ontario Canada
Fuse #12 is the one to check. Located under the dash. there are some high amp fuses in other locations as shown but onse ones for the radio
The attached wiring diagrams have great detail. To see them you must have a pdf viewer which can magnify a page. For example if you magnify a relay in the diagrams you can clearly see the relay guts.
Dave
