Kubota L47 brakes
justoldernow
Kubota L47 TLB, BX2680 w 60 in. mmm & BX2822-55 in.Snowblower
Nov 10, 2012
19
East Central PA
Been looking to upgrade from my L35 to a newer machine with more front end lift and with the skidsteer
bucket hookup (IE - L39, L45, or L47). I found a 2018 L47 with around 2800 hrs. It seems it was well maintained, front end loader and backhoe joints are solid with little or no play, all fluids are at proper levels, engine starts right up, sounds good, has no puffs of smoke when working machine, transmission feels good, general appearance is good BUT it doesn’t seem that the brakes are working. I can stand on brake pedal when moving and it hardly affects the machines motion. The hand brake lever is frozen fast but it’s in the down position so not sure if machine was run for awhile with brakes dragging. Anyway, I’m undecided about purchasing machine. I know it’s a big job to replace brakes, a bigger job than what I want to get involved with. Anyone here have any thoughts or think it’s best to stay away from this one and look for another? Thanks for all input.
4,060
Sounds like you should negotiate a price that will help offset the brake job that’s needed. (or …Has the seller already discounted it for that issue…and that price is what attracted you to it initially..??)
justoldernow
Nov 10, 2012
19
East Central PA
I think it has a decent price but if I have to spend $4,000 or more on brakes then I’m not so sure. I don‘t know what the cost would be to replace the brakes, haven’t gotten to a dealer yet to discuss. I’m guessing between 4 and $5,000 but it could be more.
10,525
On that model the biggest issue is removing the subframe to get top the axles to get to the brakes.
The parts are super cheap in comparison to the labor involved.
justoldernow
Nov 10, 2012
19
East Central PA
yeah I looked up the parts @Messicks online. Like you said the parts are reasonable but a lot of work to get in there.
