Kubota L4060 - Error Code 20 CAN NG Intermittently Tractor Will Not Start
Joematys
L4060
Jan 8, 2022
Barrie Ontario
Hi All, any help is much appreciated. Loving this L4060 we purchased.. When it gets cold it intermittently gives me an error code 20 NG CAN. Intellipanel not communicating with the ECU. When this happens the tractor will turn over but not start. Any known problems? Dealership has no idea.
Thanks again!!
kubotafreak
Sep 20, 2018
1,049
394
Arkansas, US
open or closed station? If open, check the fuse box by your left foot. They will get corroded.
4,901
re: Dealership has no idea.
sad, oh so sad,
this.. When it gets cold it intermittently gives me an error error code 20 NG CAN. Intellipanel not communicating with the ECU
says, in basic terms one computer isn't talking to the other one. (No Good CANbus)
damn SIMPLE to fix, IF you have BASIC skills .
The dealership should have one of their technicians ,consult the WSM and any other literature they have,then install a CANbus analyzer($50 to make) and then SEE where the problem is. It'll probably be wiring and or connections. The 'computers' should be OK,
check for tight wiring (tyrapped to frame somewhere)
connectors NOT seated properly AND locked
unplug, reinstall wiring at both computers
maybe 'corrosion' on the pins
'cold' shrinks things...pulls stuff apart, so look for wiring under 'stress'
Jchonline
602
Red Feather Lakes, CO
Thanks again!!
wwidmer
B3300SU
Dec 14, 2018
This is an old post but I just read about someone having this exact same problem and a very helpful fix posted by Tony Sovis, a very experienced Kubota tech on a Kubota facebook group.
Tony Sovis
If you look at the back of the tractor in the left side, mounted near the left rear tire are 2 relays. To get you going, apply heat from a blow dryer or heat gun and the code will go away. The contacts inside the relay are sticking, not allowing them to move when the key is turned and supply power to the ECU, giving you that code. I've also had luck just leaving the key on for a few minutes and it will unstick itself. I've only had this happen on machines that are outside, I believe moisture gets in the relay abs freezes.
Original post of Author with problem
Tony Sovis thanks!
Tony Sovis
I'd bet dollars to donuts that is your issue. I'm not sure if Kubota changed the part numbers, but I would replace those relays when you have time. Sometimes just leaving the key on is enough to create the heat to get the contacts to close, code goes away, tractor will start.
Tony Sovis it worked thanks!
