Ever since replacing my fuel filter housing (the canister was busted), I've been having fuel issues with this tractor. Backstory: It's a 2015 I bought with 250 hours on it, and I've put 100 of my own hours on it in the last couple years. I busted the filter housing bush-hogging, and replaced with a whole new housing (not OEM). Bleeding the system was a chore (opening the bleed valve did little at first when following the WSM guidelines). I got frustrated and walked away for a couple hours leaving the valve open, and it finally started again. But it did not have the horsepower and stuttered horribly under PTO load. My assumption was that I must still have air in the system, so I cracked the nuts on the fuel lines to make sure fuel flowed and maybe bleed some air out. Tightened them back up, and now the tractor exhaust is heavy black/sooty, and the tractor will not turn off when you turn the key. What could I have done to cause unburned diesel and no shutdown (I solved shutoff issue by squezzing off fuel line)??
