Kubota L2900 inframe engine rebuild?
garrettohio
Kubota L2900
Sep 16, 2023
41
The tractor has piston slap or worn wrist pin.should I pull the pistons and rods and put new ones in it? Or just run it like it is until have to do a complete rebuild on it? Whats your all opinions.runs fairly ok know just has a knock.only has a little blue smoke when you first start it up cold.
jaxs
B1750HST
Jun 22, 2023
536
285
My opinion is that you shouldn't attempt this as a diy. Diesel engines aren't the bag of bolts they sound like. Internal repair must be precis and held to close tolerances,one mistake can result in catastrophic damage. Find an experienced mechanic (not dealership) that will listen to it if you take it to his shop. Unless you put alot of hours of heavy use on it,it could easily last for years if you keep oil changed and toped off.
5,498
How do you know?
Neither are very common issues with a Kubota engine.
Yea you can do it with the engine in tractor but it's a pain.
4,951
1,679
pull it apart, then compare your findings with what you see in the service manual's specifications. You're gonna need micrometers, inside and outside. Dial bore gauge. Torque wrenches. Whole bunch of other stuff. Dial depth gauge.
a lot of folks think just because it's a diesel, it's crude, loose fitting, throwed together. All 100% wrong. What you see on TV is false, it's usually edited, and always dramatized. Case in point, I was "in on" a TV show a number of years ago. THe show dealt with cars. They "bought" (were donated) a car to restore, and of course being "TV", dramatized--it had to be done in 5 days. What they didn't tell everyone sitting in front of the boob tube was that the restoration took almost 3 months, but they condensed it all down so that it looked like just a few days. And the viewers ate it up.
but no you just can't blindly go about it and expect it to work, and last.
Pull it apart in frame, then diagnose it using your tools I spoke of, compare your measurements to what the book specifies, and follow those specs.
If crankshaft or block is damaged, you're gonna have to pull the engine off of the tractor. Expect to have to do that.
I usually do a compression test. If any one of the cylinders is low, I'll check valve clearance and then do another compression test. STill low? Pull the engine and deal with it on an engine stand. L2900's are pretty easy to pull the engine off of.
